1 - 8 of 8 Posts
iCloud
here is the video of my 650 VXR at idle after I just replaced the brand new ignition coil with a brand new new one because I was told the old one had a bad connection.
It’s always sounded like this just trying to see if it’s normal for it to be that loud and clanky
Discussion Starter #2
not sure if the first video link worked so try this
Video opened this time.
2strokes tend to be noisy. Yours doesn't sound bad to me. I think once you get it idling smoother it will quiet down some.
When was carb last rebuilt?
What's the plugs look like?
Have you tested compression?
Compression is critical on a 2stroke.
Did you ever find a manual? I can send you a copy of Yamaha service manual for the 94 vxr pro. But believe it covers vxr as well.
Discussion Starter #7
Rebuilt the carb less than a month ago
has been running bad not sure what’s wrong with it I just got it about a month and a half ago finally got it running but it stalls at half throttle and won’t let you give it any more gas because it hogs down especially under a load like towing a kneeboard it’s twice as bad
compression is 145 ish in each cylinder
brand new plugs and ignition coil as well as fuel lines and fuel filter
everything has been cleaned... check valve, screen, air filter etc...
I wasn’t the one looking for a manual though 😅 already got one online great deal for 14.95! Saves a lot of headache trying to “finagle” it
Discussion Starter #8
Bogs*** oops
1 - 8 of 8 Posts
