I have a few questions on reassembly of the jet pump: shaft, impeller, bearings and seals.
1. There are 2 seals that separate the impeller from the bearings, one is skinner than the other and looks to be closer to the duct. Which way do they face [the manual is not clear]?
2. What are you guys using to press the bearings on the shaft?
I was thinking about using some PVC pipe and a dead blow hammer
3. The manual says to fill the space between the bearings with grease. What type of grease are you guys using? regular axle grease? or marine grade grease?
I think that's it for now
thanks!
thanks!
