440 exhaust mani 5
Image hosting, free photo sharing & video sharing at Photobucket
start/stop w/ connectors 20
bed plate 5
intake side of pump piece 5
misc straps 2ea
misc engine mounts 3ea
fly racing grips 5
strap clips .10ea
gas caps 3 ea
fly wheel 10
a/m bilge hose, bout 24" 3
handle pole float 2
handle pole springs 2
gas fill tubes 1ea
4* bars with start/stop, wires cut 10
turn plate 3
thru hull fuel coupler 5
misc pads 1ea
h20 box hose 1
coupler cover 1
stator w/ one blown coil 20
ebox mounting bracket 2
ebox and gasket 5
ext cap, threaded 5
550sx f/a 1
working starter 20
550 sx intake mani 10
handlepole pin 2ea
38mm intakes pp engine 20ea
shaved head 10
face plate 2es
handlepole boots 1ea
throttle cable 5
carb spacer 1
handlepole bumper 1
fuel pet**** 1
battery tray 1
head gasket, not perfect but useable 2
throttle cable and carb brackets 1es
misc bolts .5 ea
pimp mounting bolts .5ea
shims .25 ea
pump nuts .5ea
550pp engine, almost complete. needs stator, and starter. 120 psi in both holes. i was told it had a shaved haed, but otherwise all stock 200 OBO
yellow handlepole 10
pink hood 25
skat trak 15.5* impeller 50
bed plate 5
misc straps 2ea
fly racing grips 5
strap clips .10ea
gas caps 3 ea
fly wheel 10
handle pole float 2
gas fill tubes 1ea
turn plate 3
misc pads 1ea
h20 box hose 1
coupler cover 1
ebox and gasket 5
ext cap, threaded 5
550sx f/a 1
working starter 20
handlepole pin 2ea
shaved head 10
face plate 2es
throttle cable 5
carb spacer 1
handlepole bumper 1
fuel pet**** 1
battery tray 1
misc bolts .5 ea
shims .25 ea
pump nuts .5ea
pink hood 25
