Anybody know where I can get a download of the software... ? I have a DI so I've got problems .... :)...... They seem to go hand in hand... It's a good thing I like working on stuff. So far I have cleaned out the gas tank (but load of rust )..put a new fuel sensor in it, Cleaned the filter on the pump... , put new inline filter on it, new head gsket , checked the reeds they look good... compression is good.... It runs every time I try to start it, sometimes it will even rev up and take off then the check engine comes on and she will only idle and bog if I try to give it gas. Then sometimes the check engine light will come on when its idling... Im thinking the fuel pump might be weak going to try pressure testing the fuel line should be somewhere around 29lbs when idling I guess and hold it..... Maybe the rust hurt the pump....? Any Ideas would be great
