Stx Display
Hi i had a simlar problem My display showed low battery even with a new one fitted and keep changing between fast and slo mode while running
I found display gets water inside shorting connections
Kawaski Usa are awhere of problem a seem to support customers kawasaki australia donnt help
Display is $600_1000 aud You need to be extemly carefull when washing not to spray display and the dealer told me if you flip ski water will get in no warranty as it will log a tip code to ecu make shore if you flip you remove meter remove rubber bung and clean any water out you can clean with isobolic alcahol or metolated spirts leave to completly dry before re install
