I just got a 92 750ss and found it to have a long hesatation when starting out giving it full throttle. After it gets up on plane it runs wide open like it should. I have tried to adjust the air/fuel mixter skrews and it made no diffrance. I removed the oil injector system and mix my on to 50:1. I checked the compression 152 and 148 on the other. The guy i got it from said he had just rebuilt the carb and replaced the reeds to try and correct the same problem. It seems to me it is running real rich as the plugs are real wet. Any sugestions on what to try next?
