I'm new to the forum. From what i've read so far the 97/98 GSX Ltd. has some problems. I'm looking at one that's been sitting up and hasn't run for over a year. The owner says it took on some water and began to run rough then wouldn't start at all. Cosmetically the ski looks pretty good, the trailer is painted steel and rusting from saltwater use. I plan to take a jump starter over tomorrow and see if it turns over then do a compression check. If this checks OK I plan to make an initial offer. Can you guys give me an idea of the fair market value? Also, from reading earlier posts i know one of the first things to check is the ignition box. Other suggestions?
