we have a 1994 tigershark montego deluxe,it seems to run good but its almost imposable to start.So tool it into my local dealer and they said it had low compression in one hole,i told them to put it outside and i would come and get it.Do you think its bad rings,maby a burnt piston?Is it worth fixing?Will the other side be next?Does the motor have to come out?The motor is a suzuki and the only numbers i can find on the tag are 06801j-452129 does that mean anything to anyone?Thanks for any ideas or help you might be able to give. Jon
