1 - 5 of 5 Posts
I love my 2004 FX HO. I did, however blow the head gasket at 220 hours. I had a shop do the head gasket and the ski runs great and does not overheat. I still have milky oil though after 5 oil changes! With each oil change I run the ski for at least 15 mins in the water at speed, suck 2 1/2 quarts out of the crankcase, and drain or change the filter. It doesn't seem to be "making oil" but not sure I run it long enough to notice. I have only put a couple of hours on the ski since I'm scared I'll blow it up with this watery oil. Any help would be greatly appreciated!
Mike Brown,
Ocean Springs, MS
Seems excessive. As you've been changing oil does it look to be clearing up at all? Or staying pretty consistent? If not clearing at all I'd say you still have a leak.
Roughly you've changed all the oil about 3 full times. You should be seeing a significant difference by now.
1 - 5 of 5 Posts
