1 - 5 of 5 Posts
i thought my electric box was bad so i bought a clean complete off someone...everything inside looks great and well taken care of.. so i really dont think thats the problem now, it cranks over and acts like it want to start but then it backfires out of the carb..it has spark,getin fuel, i just cant figure it out..can it be my stator..? thats the only thing i can think of...it was doin the same thing with my original electric box...a few people told me it was the coil pack so i decided to replace all of it, after seein water and sand inside...can someone give me a idea of wut it might be...thanks
Pull the flywheel and check the woodruff key. Sometimes they shear and it changes the timing . You will still have spark, and fuel, but it will just pop and fart.
I agree with this guy, Im a newbie when it comes to these skiies but I know if your backfiring through your intake(carb) then the intake is open at the point of ignition thus firing through the carb and it should be firing with all valves or reeds closed.
Discussion Starter · #4 ·
k.. pulled the tank and cover off today..i dont have the right size socket to take the nut off the flywheel, ill grab one from work tom.. but i was lookin at the teeth of the flywheel and some of teeth are worn down on the inside part of the wheel... does anyone know wut that can be cause from..? before i open a big can of worms tommarro...
Discussion Starter · #5 ·
well took the flywheel off today and my mouth droped..!! the shaft is all chewed up, the inside of flywheel is chewed up, the woodruff key is sheered, it does not look that good at all, any ideas on how i can fix this..? would i have to buy a whole new crankshaft..? or would i be able to weld it an fill in grooves then polish it..? check out the pic.. thanks
1 - 5 of 5 Posts
