My zxi 1100 will not idle and runs really rough at low rpms. To get it started I have to pour gas straight into the carbs then it will run but if I let it sit too long will not start again unless I pour gas in carb again. It has new fuel lines, I'm getting gas from the selector to the filter, new fuel filter, new pump, carbs are cleaned and look great, what else could it be?
Super Moderator
What year is it ? What brand kits did you use ? Did you replace the needle springs with the ones that came in the kit, and if so, which springs did you use ? What did you set the mixture screws to ?
