I have checked the spark plugs, I checked the fuses, and I ordered a new relay switch. I installed it and the same thing is happening. when I hit the start switch all I get is a click sound and a winding sound. I have a new battery in the ski, and the security light is on. I am hoping it is not the starter, because it sounds like it is not getting to the starter. please somebody help me with this problem. I had a xl700 and I rebuilt the engine on it and the carbs, so I have experience working on two stroke engines.
I responded to your other post on the same subject. You have two large systems. The starter system and the engine system. I suggest you separate them and do mechanical and electrical measurements on both systems to determine the cause(s) of the problem(s).
Your first step should be to purchase a shop manual
