I just got my Ski ready for winter, when i put in the battery and attempted to start up the ski my battery light went off.. Although my battery was fully charged.. I then brought out the jumper cables and the light stopped blinking, but then the engine started cranking itself without me pushing the start button and only stops cranking when push, and hold the stop button.
Sounds like your starter solenoid is stuck in. There is 2 posts on it and if you have 12 volts on both without pushing the start button then it is stuck. Whack it with a screwdriver handle or take it apart and see if its corroded. Or take the handlebar start switch apart as it may also be stuck.
