I think I figured it out. I took a test light to the to hot post coming out of the electrical box. The first post that the red wire should always be hot as long as the battery is working goes into the starter relay. The other post coming out of the relay should not be hot until the start button is pushed and when I pushed it the light did not turn on. So I took a screw driver and crossed both of the post bypassing the relay and the ski turned over confirming that it was not the started and infact it was the relay.
Thanks
