My wake won't make a left turn. I found out that the direction nozzle is loose and the force of the water pushing the nozzle back straight when turned to the left. There seems to be a lot of play in it so I thought the steering cable nut might be broken. Took the pump apart but the nut seems fine (will replace with metal anyway will I have it apart). There is a lot of side to side play with the steering cable. If I hold the external sleeve the inside cable moves a lot. Is that normal? I can't seem to figure out a way to tighten the nozzle to remove the play. Any suggestions or ideas?
Thanks,
Thanks,
