Hey all
I have a 99 seadoo xp limited that has set for 2 years i changed the plugs put a new battery in and fresh gas, went out it started right up and idle fine
runs good up to 2200 rpm but flat dies after that point no clue where to look any help would be great.
Wow! I consider you pretty lucky just putting a battery and plugs in a ski that has been tits up for 2 years! did u do a compression check? sonds like rings are stuck overheating and shutting down? water in fuel? 2200 RPMS is very low!! is it getting lube? carbs working correctly? old fuel? this list is end less but here are a few basics you can start with, good luck!
