just got motor rebilt and puting it back togther should i get new reed valves also any thing els i shold do while its on the bench its a 951 gtx limited 1999
Hi all!
I have a 1993 seadoo xp that is apparently clogged. It shut down, got the overheating beep when trying to start it. So i let it cool down, started it out of water and plugged the hose in but no water is coming out the tell tale.
Where would you begin? Any tips are appreciated!
I've had issues with this ski since I bought it new. When in rough water, rough enough to take water in your face, the ski fills up with water bad. I've checked out the engine and hull in calm water and everything's great. So I poured a bucket of water over the front and sure enough water gets...
i have a 2003 seadoo GTX 4-TEC 185h supercharge. i have recently replaced the fuel pump and rectifier on the ski. when the rectifier is connected, the ski will start and idle for approx 30 seconds before it begins to drop its revs and stall. if i disconnect the rectifier, the screen flashes...
Hi all. I swamped my 96 GTI lastnight. I pulled it out, pulled the plugs, cleared the water and got it going again. It starts easy and up to 3/4 throttle runs nice. But if I try to go faster if feels like it is starving for fuel and cuts in and out..... what did i do? Cam.
Hi All, I recently acquired an '02 GTX DI on the cheap as it had some known issues and the current owner was tired of dealing with it.
Came to me reportedly with a faulty TPS. Took those off and both tested fine - hooked up a candoo and no active faults(though showed previous tps related...
