sale is a NEW 2010 Sea-Doo GTX limited iS 260. This watercraft comes with a 4 year limited warranty and will get a pre-delivery inspection by a certified mechanic.
DIMENSIONS
LENGTH 139 in. (354 cm)
HEIGHT 43.9 in. (111.4 cm)
WIDTH 48 in. (122 cm)
WEIGHT 980 lbs. (446 kg)
ENGINE
ENGINE Rotax® 4-TEC®
HORSEPOWER 260 hp
DISPLACEMENT 1,494 cc
BORE X STROKE 100 x 63.4 mm
COMPRESSION RATIO 8.4:1
FUEL TYPE 87 octane minimum, 91 octane recommended
FUEL CAPACITY 18.6 gal. (70 l)
IGNITION Digital inductive
STARTER Electric
COOLING Closed-loop
DRIVETRAIN
TRANSMISSION iBR™
PROPULSION SYSTEM Sea-Doo® Direct Drive
IMPELLER Stainless steel
INTAKE Supercharged with external intercooler, 52 mm throttle body
PUMP Aluminum axial flow, single stage, large hub with 10-vane stator
ELECTRICAL
BATTERY 12V
BODY
HULL MATERIAL Composite
HULL TYPE Deep Vee
STORAGE 16.4 gal. (62 l)
OPERATIONAL
SEATING 1, 2 or 3 riders
DIMENSIONS
ENGINE
HORSEPOWER 260 hp
STARTER Electric
COOLING Closed-loop
DRIVETRAIN
TRANSMISSION iBR™
ELECTRICAL
BATTERY 12V
BODY
HULL TYPE Deep Vee
OPERATIONAL
