coldjustin said:
ive spent quite a bit of time on the honda these past few weeks and it is pretty stable and i want to take care of it the best i can. it is very reliable and doesn't really use that much gas saturday i went out in the main channel with it and it handles the rough water much better than i thought it would. after i got it out of the water i pulled the plugs expecting water but not a drop.the only two things i dislike is that i cant pull a tube and that it holds water in the foot hulls. this is not a big deal but it will throw the balance off a little.any suggestions on what to do after i get the ski home after being on the water or even when it is sitting? very happy with the ski and glad to have everyones help.
Most never pull the drain plugs out as there has never been any water to drain out in mine. Unless you flip the unit you will not find much water in there. It is not worth the risk of removing these plugs as you might forget to replace them! <vbg>
Water in the foot wells is unavoidable. If you slow down too quickly and fall off plane, the wake behind you will fill the wells up. A quick blip of the throttle and out it goes. With time you will be able to slow the ski down and avaoid the well fill up!
My routine when I get home is to flush the engine, read th manual and get the adapter that fits on the flush pipe. NEVER force water into the flush pipe unless the engine is running. READ the instructions. It is not complicated but there is a certin way to do things when flushing the engine. Wash/rinse off the entire exterior, I use salt away for both flushing and washing as I am in Jacksonville. Fog you engine with fogging oil, unscrew the throttle lube coupler and shoot some oil in both and rescrew them together. shoot the linkage on the turbo. I leave the seat off for a few days with a fan to make sure no water is trapped in the engine compartment. Wax the exterior on occasion and apply protection to the seats. lube the throttle cable. every 50 hours have it serviced with a oil change
have fun
