I could use a little help!:dunno:
I got a 97 Kaw zxi 750 twin carb. It fires up, idles, & revs up great out of water (running off the garden hose). Once I put it in the water every thing is a little more stubborn. It idles a little slower & rougher like a cold engine does, but its still going. After it warms up for a while, I get on the throttle hard & fast & it bogs down & stalls. It's a little stubborn to start after that but once it catches again its acts the same as earlier. If I feather the throttle a little it grabs & takes off like a bat out of hell. If I stay on the throttle its fine. Once I let it go it sounds like it wants to bogg down & stall again till I catch it with the throttle & keep it going. I called a couple of places one said the air/ fuel mix screws need to be played with. The other place said the acceleration pump is clogged. The guy I got it from said the carbs were recently rebuilt, He was thinking that it was a stater problem. I was playing with the air/ fuel mix screws but because it’s not in the water with a load on it I can’t tell if I made it better or worse. Can any one help me before I sink this thing for good? THANKS!!!!
ead_Horse:
