With ignition switch ON nothing on my 900ZXI would work, no idiot lights, no trim and no starter, no nothing.
If you have the same problem check this out
The electrical power problem on my 900ZXI was because when the start/stop/trim module when fastened to the handlebar for some reason the stop switch was activated. I used a dremal cutoff wheel and cut 1/8 inch off the end of the plastic switch plunger and it fix the problem.
