1 - 4 of 4 Posts
could be a number of things,check to see if you got spark, a continueing spark as you turn her over .if not check coil,if coil okay it may be the CDI, also make sure your kill swich is okay and the wires in the box are secure,good luck
thx born free never thought of the coil was thinking the cdi went out u have any idea how it is to change the cdi? 1 more thing how can u check out the coil? i have 2 of theses old things may just try to switch the stuff from one to the other and see what happens
Clean/replace the plugs. I had the same thing happen to me on the same exact watercraft a couple of weeks ago. My initial problem WAS gas (reserve didn't work) but after I filled it up it still wouldn't start. Pulled the plugs and cleaned them and it started right up and ran great after that...
1 - 4 of 4 Posts
