Does anybody sell an OEM Sea-doo topend kit? I have a 2001 GS 720
Thanks
Dan
Hi Dan,
To my knowledge there is no OEM 'Top End Kit', however all the parts are available. You have to order the following parts from your dealer:
1. Cylinder Gasket Set (P/N: 290 886 316) - $89.99 - (Qty 1)
2. Piston with 2 Rings (P/N: 290 887 670 (Stock Size) OR 290 887 671 (0.25mm Overbore) OR 290 887 672 (0.50mm Overbore) - $114.99 - (Qty 2)
3. Piston Pin (P/N: 290 916 402) - $30.99 - (Qty 2)
4. Circlip (P/N: 420 845 100) - $1.33 - (Qty 4)
5. Needle Bearing (P/N 290 832 420) - $20.99 - (Qty 2)
Total - $429.25
That is all the parts needed for a "Complete Top End". However you could just order
This kit from eBay for only $177.96 (Shipped) which is a complete top end kit made by
WSM Performance Parts, which is considered to be an equivalent to the OEM parts.
Hope that helps.
-TheChad
