Oil Block off... Can I remove the whole system or do I need to leave oil in the tank?
2025 Views 4 Replies 4 Participants Last post by  tparks87
I have an 89 Sea Doo SP and I ordered and oil pump block off kit and I have taken out the oil system (haven't run it yet) I am just wondering if there is something in this engine that isn't lubed by the oil pump that requires there to still be oil in the tank.
1 - 5 of 5 Posts
These are my notes on the '95 SeaDoo XP that I removed pump from
Oil Injection Pump
To disable the pump on your engine you must pull the intake manifold & remove the drive gear,
If using oil pump as block off plate, then hook the two oil nipples together with a piece of the oil hose to prevent air from being pulled in
You may also need to add some tension to the carb return spring as the oil pump spring is part of the return tension for the throttle cable
Good time to rebuild carb, New carb filter, New fuel diaphragm
Oil tank
You must leave your oil tank in because the rotax engine's rotary valve chamber must be kept submerged in oil.
Leave the 2-oil lines attached, one to the motor, and one leaving the motor, going back up to the reservoir (on top)
That is how the main bearings are lubricated.
You can loop the oil lines on the motor together and fill it with oil and remove the oil tank. Just don’t fill it slap full due to expansion. I looped mine on my 90 and removed the tank.
is this true? what about the rotary valve, I feel like the carb side will get its lubrication from the fuel oil mix, and the engine side will be lubed from filling and looping the line? am I correct in this thinking?
1 - 5 of 5 Posts
