1 - 5 of 5 Posts
I am new to the stand-up world. I aquired an 89 650SX and am doing a rebuild b/c it needed a little work. I am considering the block off kit but have a couple questions. If I use the block off kit is the oil mix 40:1? What type of oil do I use in the crank case 10/30w? Where can I get my hands on an inexpensive block off kit? Thanks for any help.
i've never dabbled with a block off kit but you don't want to put oil in your crankcase. that's the point of mixing it with the gas.
http://www.pwcforum.com/vintage-jetski/2436-1977-js440-oil-question.html
http://www.pwcforum.com/vintage-jetski/3540-650-sx-basic-questions.html
40:1 or 50:1 would be a good guess for the mix. its 40:1 on 550's but 50:1 on the 550SX's with the reed valves. might have to ask someone smarter than me to get a solid answer.
Hey I just wanted to say thanks. You basically answered my questions. I have the engine broke down and need to put it back together should I grease the connecting rods and bearings before firing so that there is some lubrication throughout the engine while the premix is circulating and lubing the joints?
yeah i think i would out a dab of oil or something on those joints as you button it back up...maybe a shot of oil on the cylider walls too.
1 - 5 of 5 Posts
