I have a 96 slx that will crank but will only idle and that's rough. I pulled the plugs and turned the engine over and I get what looks to be way too much oil.
This may/may not be the problem. Someone told me that I could by-pass the oil injection pump and just add oil the gas tank. Is this possible? How do I do it,
disable it or just remove the oil?
If the oil injector sounds like the problem, and by-pass not advised:
Is there an adjustment a shadetree mechanic can do?
Any advice would be greatly appreciated.
