I have a 2000 GP1200R,& just installed a oil block.
What is the right oil mixture?
32:1(20oz to 5gal.)or 40:1(16oz to 5gal.)
Since you have already undone oil injection (????) not sure why, but until you know the mix is right I would go 40:1. It may be smoky since at an idle oil injection is about 100:1, then changes the ratio through out the power band. So by premixing the only time you are at the right ratio is at WOT. Which most two stroke engines are a 50:1 ratio.I have a 2000 GP1200R,& just installed a oil block.
Everyone that is familiar with this unit knows that one of the main problems is the oil lines come loose & many have blown their engines.Since you have already undone oil injection (????) not sure why, but until you know the mix is right I would go 40:1. It may be smoky since at an idle oil injection is about 100:1, then changes the ratio through out the power band. So by premixing the only time you are at the right ratio is at WOT. Which most two stroke engines are a 50:1 ratio.
Good luck with trying to balance it for all speeds without fouling plugs. You may want a gas mask for start up. They invented oil injection for a reason......
So instead of replacing oil lines we go backwards in technology and emit more pollution??? Bummer Yamaha:thumbsdown:Everyone that is familiar with this unit knows that one of the main problems is the oil lines come loose & many have blown their engines.
I've done my homework & talked to a few owners.
Does that model have the powervalves?I have a 2000 GP1200R,& just installed a oil block.
thanks for the great infoOK I found the info on SBTs forum:
Post Pre-mix stock oil ratios
If you have removed your oil pump and gone pre-mix, these are the correct ratios you should be mixing to, after the first tank of break-in. These are the stock ratios the factory pumps put out at WOT:
32:1 = 4oz/gal
40:1 = 3.2oz/gal
50:1 = 2.5oz/gal
Sea-doo
40:1
Yamaha
All but 800 & 1200pv 50:1
800 & 1200pv 32:1
Kawasaki
50:1
Polaris
40:1
Tigershark
40:1
