On the note of the spark plug, take the plug while it's attached to the wire and ground it to the engine while cranking. MAKE SURE TO USE RUBBER HANDLED PLIERS OR YOU WILL BE SHOCKED. If it sparks while doing this, you're plug wire is good and your ignition system would appear to be operating correctly.
If the above stuff seems to be working, the next step is to check the compression of each cylinder.
Keep us posted so we can keep helping!
