I'm having a problem getting my 93 750ss to start. The engine cranks strong but it just doesn't seem to want to turn over and start. It's not until I spray a whole bunch of Engine Starter Spray in the cylinders that it finally turns over and off I go. I tried adjusting the carb. screws but that didn't work. Please can someone shed some light on this problem.
I'm also having a problem with my 1996-97 750Zxi. The darn thing always needs a "BOOST" with a battery booster every time and yes, it does have a fresh new battery! The electrical works because the "trim" adjustment works fine even when I'm having this issue. For those who know about this Ski I know when this problem is going to happen and it's usually when the (2) orange check lights don't flash on when you initially turn the electrical on. It almost seems like there simply isn't enough juice for the system to recognize and doesn't pass the systems check therefor not letting me start the engine. Please help me..
-Thanks in advance....
