i have a 97 montego i am very new to jet skis this is the first time i started this guy up and it has a loud rattle sounds like metal on metal grinding rattling its coming from either all the way in back or underneith please help any ideas pleaseee
no just remove the 4 bolts on the back of the ski and the rubber water hose and everything will come out then i dont know if you have the update shaft that it screws to the motor or it just slids in to the motor but no matter what the shaft has to come out so you wont damage the bearing
cool so i pulled that whole back off the drive shaft just slid out however it wont let me pull all the way out its getting stuck somewhere but with that off motor sounds great no rattle so its somewhere in that whole back part
you better hope its not your wear ring cuz its a $300 plus part. you must remove the prop with the housing so you can spine the prop by hand woth the prop next to your ear and listen if thats the sound you hear. lets not worrie about the wear ring right now so do that fist then i will tell you how to aline the motor
if im doin it right i dont hear any noise when i spin it by hand the only things i notice so far is the long rod thats conects to the impeller has play in it up and down not sure if thats normal the floating bearing seems to have a hairline crack starting the impeller has snall nicks in it
if you can remove the driveshaft and remove the floting bearing and turn the bearings with your fingers if its ok then see if your shaft is not bent and look at your motor coupler see if it does not have play
