ok on this last test your going to need another person to help you. put the pump back on and have your helper turn the driveshaft by hand. you will be at the back looking at the prop and wile your helper is turning the shaft look at the prop and wear ring and see if they are touching each other. if not then i have a quick temp fix for ya...
