Hello... I recently purchased a summer cottage that came with a 2000 Polaris genesis 1200 (carb). My problem is its been setting for 4 years (winterized). I would like to prep it before summer and don't know where to start. I drained all the old gas but I am worried about the ethanol effect. Any help would be greatly appreciated. Thanks
Anything that sits for that long will need at the bare minimum carbs cleaned, fresh gas, new battery, plugs, check all electrical for corrosion. Hopefully the engine was stored properly and fogged. If its oil injected check the lines. Run premix in it the first tank in case the oil lines are empty.
Sent from my SM-G973U using Tapatalk
Thanks J-hook... already changed fuel lines , battery and plugs . It had been fogged … I'm on to the electrical system now . Again thanks
