I'm a newbie and just bought a 1992 Yamaha Waverunner. When I took it out for the 1st time it ran just fine. Problem was when I turn right, the jet ski turned just like should. When I turn left...at made MUCH wider turns. At 25mph a right turn took 12 ft or so, a left turn took over 50 feet.
When I got it out of the water I checked the steering to see if the jet at the back turned as you might expect. It turn freely in both directions (and at the same angles).
What should I check??
Thanks so much for your input.
Sheldon
Sheldon
