it not a stator shaft if your trying to get the impeller off. Its the drive shaft. If it doesnt have a hex shape cast into the prop which you can put in the vise and undo the shaft with a pipe wrench, it must be an aftermarket prop that requires a special tool to take off. Usually take the nose cone off the prop and the tool inserts in there.
