I know this sounds like a crazy question, but on the Kawasaki engines, which side of the dipstick shows the correct fluid level? I know one side is hot and the other is cold, but mine actually shows two different levels on each side. I know it doesn't seem possible, but there is about a 1/4 inch difference depending on which side you are looking at. Again, I know the scale is different on each side. But the fluid level is actually higher on one side than the other. So I'm either dead on where it should be, or I'm a 1/2 quart low.
