Try carefully using a heat gun on low or a hair dryer. Just enough to soften the glue, but not enough that the hull gets hot (that goes for the rest of the hull in the foot wells also). Residual hot air can get the sides. You can also get a rubber wheel for a drill off amazon designed to remove stickers and adhesive.
I believe the factory was rubber, so they might very well be aftermarket.
