Could use some help guys. Have 2 '95 Sea-Doo SP's that were purchased new.
They have developed a rattle at idle speed when in the water but not on the trailer. Had a guy tell me it was due to end play in the impeller shaft due to wear. He also told me that later model years had some sort of a spring setup inside the impeller housing cover that would pre-load the shaft to the upper end under spring tension and not let it move. According to him, these parts could be retro-fitted into some of the older models including the 95's. Does anyone know anything about what he was talking about? I would like to get what I need to do the retrofit on my Doos and get rid of the rattle I've been listening to for the last several years. Any info such as part names or numbers of the necessary parts would really be appreciated. Thanks.
