So last time on the water early summer my son was tearing around and it was running strong then just stopped. I thought the battery was dead as it barely turned over. I towed it back and charged the battery but it wouldn’t crank over. I couldn’t turn pto by hand but could with a pipe wrench and some oil down the cylinder holes. I noticed some oil in the hull and suspected a crank seal / bearing. I brought it home and left it until now. I can now turn pto by hand with spark plugs in! I pulled the engine and can’t see where it was leaking oil? All oil lines appeared to be intact and not leaking. I removed lowest bolt on magneto housing thinking oil might me evident but nothing. Please assist. Thanks
