ROTFL I told ya to watch out for the spray, glad I could help.WOW .... IT worked.
I used some rust blaster in each cylinder .... cranked the engine with plugs out.
Sprayed some starter fluid in both cylinders ... put one in and the other sitting on the hole.
Started right up but did not have the exhaust pipe hooked up yet and ended up both the ski and I were covered with oil/water/other fluids from the engine.
Put both plugs in and the exhause pipe on and cranked a little hard but started and runs great now. THANK YOU !!!
Most any parts store. It will be labeled Rust Blaster, Break Away, PB Blaster, CRC makes some. Marvel Mystery oil works good too. Just ask if you can not find it, they will point you in the right direction.hey where can i buy rust blaster at?
