1 - 15 of 15 Posts
Actually flipped over this machine, this happened last summer and I didn't do anything until this summer but what I've done so far was.
I took off spark plugs, shot the water out of the engine by starting it repeatedly, replace with new spark plugs, check spark plugs when starting while off machine and I'm getting a spark.
I'm getting a light spark tho. I'm not sure what the level of the Spark should be, maybe it's not strong enough. Battery is fully charged. Gas is getting in the engine.
So that's pretty much where I am with this
Discussion Starter #4
So the engine has been sitting with water in it since last summer !!!???
Yes, I'm new to these issues, but i'm pretty handy, I'm a 20 year carpenter, just need to know what I should attempt to do next. I was also think maybe there still some water in the engine mixing with the gas as i'm attempting to start this machine.
Thanks
JB
Super Moderator
Water sitting in a two stoke is detrimental. It will rust up all the bearings. If you were to get it to run, I will just about lay money that you might have 2 hours use before it self detonates are the bearings fail. You would be lucky if it didn't totally destroy the cyl's or worse.
I would either get a rebuilt crank in it along with new rings, wrist pins, and wrist pin bearings now. At least this way you should not have to bore and get new pistons.
Other option is getting a good used engine, but you are taking a chance there.
Discussion Starter #6
Wow, engine work, I would have to get a shop to do all that and it sounds expensive. How much would all that cost, your suggestion?
If it rust in the engine, perhaps a motor flush with some sort of rust-olem then a lubricant, i'm just trying to figure a cheaper way out here
Super Moderator
Once the crank bearing are rusted thats it. When u run it, it will wear the rust off quickly and have extra clearance.
Discussion Starter #8
Thanks buddy, I been searching for a guy to repair the ski, no one here in NY wonts to work on older units, smdh, everyones saying my 98 XP in to old but I also have a really old jet ski named Wet Jet lol, it's a 95 but this ski went thur hell but every year it starts right up with a boost.
I can imagine me trying to get the wet jet repaired.
I just asked about a 717 rebuild and replacement... $1850 all in by someone who builds them himself... farms nothing out. It's expensive but you get what you pay for. $899 for a rebuilt engine, $80 for tax, you are at $1000 and you haven't got it installed. If the replacement took 5 hours @ $80 an hour labor you are at $1400 with a replacement engine. $1850 actually seems reasonable at that point... But you can find running jetskis for $1500 out there, for $2000 you can find some that actually look nice with good compression... but you are always rolling the dice.
I have been told that if you get water in an engine, remove the plugs, crank to get water out, then get it started ASAP. Run it for at least 2 hours to get it and keep it hot... it can help remove the water. But bottom line it DO NOT LET IT SIT.
Discussion Starter #11
Thanks. I pumped out all the gas, remove the spark plugs again to clear all gas from engine after failer to start in days, I was thinking maybe the spark is to weak to start engine so after removing plugs I reattached it to the wire then started to see the spark and the engine caught on fire.
Fire was everywhere because gas was everywhere, this was a nightmare, smh. I grabbed the fire extinguisher that's in the jetski compartment and of course it did not work. Fortunately I had the water hose there and put the fire out. But after pumping out all gas and replacing with new gas dam thing started right up.
This was a 3 day nightmare but at the end all appears to be good, today I will drop this ski in the water. Wish me luck.
Thanks guy
JB
Thanks guy
JB
That's a new way to get a ski to start.... if you want to know if you have spark, they make $6 tols at harbor freight that will show a bulb flashing if the wire is getting the signal... how "strong" the spark is... i don't know, but if you are getting spark, i tend to think it's binary... it sparks or it doesn't. Maybe that's not right, others can comment.
Still, with water in the engine that long, enjoy the ski until it dies... but my guess is it will die... stay close to shore!
Discussion Starter #13
Stay close to shore, lol, Copy that.
Also my friend will be riding that ski, I don't care for that one but I will let him know this an thanks buddy
Thanks again
JB
Discussion Starter #14
I have another problem, there's gas leaking badly from the bottom of the carbarator, it's a simply hose. But the problem is I can not reach it to remove the clamp, and I'm sure installing the new hose and clamp will be twice as difficult.
I was think of removing the top fiberglass body of the entire jet-ski, then perhaps i'll have the room to work here, smh. Do you have a solution for this issue?
Thanks in advance
JB
1 - 15 of 15 Posts
