viragetx said:
and can i do anything inexpensive and easy myself to mine?
92 Octane domes
Prok or the like flame arrestors
V-Force reeds
Hot Seat waterbox
Ocean Pro rideplate
6* wedge
NuJet 7.5 impeller
Go grab a fistfull and never look back. He'll be chasing you forever!!! This setup has proven to be one of the best sleeper packages around, and delivers as advertised.
You will gain an honest 4-5 mph and never even have to rejet the carbs!!! (
although, you always want to check to verify this)
If you want to keep it super simple for now, add the 6* wedge and cut your stock sponsons and gain a couple of mph.
Cutting the last, rear section off of the stock sponsons will allow the nose of the boat to rise and result in a speed increase.
Simply remove the stock sponson and cut the last section off, making sure to leave that last "web" in tact.
Reinstall in the stock location (all the way forward) and fill in the now empty hole with a bolt that's roughly a 1/2" shorter.
It's a nice little increase and best of all, it's free!!!
If you know that you're going to be riding in some ugly water, you have the option of moving them all the way rearward to help plant the nose again!!!
Your boat actually came with a nice rideplate, but for sure, add the 6* wedge.
Hope this helps.
