If i disable the oil injection on my 1992 polaris 650 sl what should I mix my gas to. Thanks
K ktf9599 · Registered Joined Sep 16, 2006 · 1 Posts Discussion Starter • #1 • Sep 16, 2006 If i disable the oil injection on my 1992 polaris 650 sl what should I mix my gas to. Thanks
A addicted · Registered Joined Aug 10, 2006 · 30 Posts #2 • Sep 19, 2006 40:1, but make sure you pre mix it, run it with the injection and mix, then pull the pump. Otherwise you could fry your engine.
