Having a bit of an issue with the starting of my PWC. It wouldn't start.
The conection in the electrical box was loose.
I tightened up all conections. It started and worked for a few days. When it wouldn't start again -i removed the starter. The terminal post was loose and almost imposible to tighten. I removed the exhaust manifolds to get at the starter.
The terminal post turns freely. I need a new starter. Do you guys have a good source for new parts? Not used? I also, live in Canada so, shipping can't be an issue. ALSO, the speedo tube fitting has broke off. My machine takes on water. Is there an easy way to replace this broken fitting? it is under the drive.
Thanks Paul
Thanks Paul
