I bought my slt 750 with the problem of it dying if a gave it full throttle. The first thing I went through is my carbs, after that I pulled my heads. Upon inspecting my heads I found that my piston that is closest to the pto(the rear most piston) had a crack in it about 1/2 inch along top of piston. I honed the cylinder jug and put in a new piston. I ran it for about 1 hour out of the water hooked up to the hose, everything seemed to be working great. Later that day I brought it down to the lake idled around 10 mph along the shore for like 20 minutes, still everything good. As soon as I ran it at around 80% throttle for around 20-30 seconds it dies, not able to restart. Upon inspection I had burned a hole right through my new piston, and their is minor aluminum deposits from it on the top of my jug. So I guess my question is what is causing my rear piston to have so much problems. I have heard that it has to due with the fuel pump not sufficiently pumping to all 3 carbs equally, and also that my oil pump may not have been working properly, but it was. Any suggestions would be helpful.
