Heh Guys , need some help on this one .I have a 88' 650sx Kawasaki that got nailed in the front this last weekend . The front is caved in under the front rail and the rail where the eye bolts into is gone . Is there any aftermarket stainless steel reinforcement kits to beef front up , also to help me rebuild front end. I have seen them on 550/ 440's before. I'd lose trim if needed to mount it. I can fix hull with fiberglass but the reinforcement that was built into lip is broken . Any ideas on how to fix , I don,t believe I can use stock trim after fixing do to bolt length ; most likely will be to thick of a lip to penetrate. Any help would be awesome
Joel
