I got the engine on the floor, tapped out the starter bolts that I broke trying to get it out but the new starter revealed yet another problem, the old starter appeared to have seperated from the end part so here are a couple pics if someone can confirm this before I try to beat out the part that is stuck, I swear it looks like it is one piece molded to the block. I pulled the cover and I guess I need try try and tap out the race or bearing that is revealed from the inside? Is that right? I hit on it a few times with a punch and it didn't budge at all, from the outside it looks like one molded piece. One good point is the inside gears under that cover look like new!
Thanks, rhutson in NC
