Since you didn't specify year, make and model, they all have a flush fittings, whether on the engine or a fitting next to the jet nozzle. Don't run for more then a min or two as the seal carrier and bearing on the drive shaft will overheat. There primary function is to flush the cooling system with fresh water.
