ok i have searched the forum for boggin problems but cant find anything that helps........ so I'll ask.
1996 KAW 750 ZXi
when the ski is on the hose it starts, idles, throtles up and down perfect, you woudnt think any thing is wrong, put it in the water, and it wont come off of idle with out boggin down. it will take a small amount of throttle, just enought to get it moving but anything more and NOPE.
checked impeller, clear.
pulled it out of the water, put it back on the hose. Stated up great. Now the first two time I tried to throttle it, it bogged down (on the hose) but then it cleared up, and would run fine, throttle up down start........again you wouldnt think anything is wrong.
I bought this ski last nov thinking everything worked fine. When I bought it it seemed to run great (on the hose). Id run it once a month to keep the fluids going and battery charged. now that I wantt o use it she has this boggin problem.
ANY Ideas, pls help
THanks Marty
1996 KAW 750 ZXi
ANY Ideas, pls help
THanks Marty
