Hi Guys, I just bought my first ski, i got what i thought was a pretty good deal. It does however have a light issue.
The story goes like this.
Guy hasnt had ski running for 2 years, starts it up hooked up to water, and shreads what looks like a rubber seal/ bush on the shaft that is connected from the engine to the jet (on the jet side) he quickly turns it off and leaves it.
So my question is what is the best way to repair this? do i have to pull the engine out? anyone know where i can get this part? should i be raplacing anything else at the same time?
Also what other things should i putting my attention too before i use the ski.
was planning on draining the oil and fuel, cleaning the carbys out, maybe run a rich mix to start with, change fuel filters, lube up all the linkages and cables,replace spark plugs and leads, and generally just check everything over and replace wheel bearings and springs.
Thanks in advance guys
Craig
Craig
