Looking for help. I just bought a used STX1100 dI and went through everything. I messed up and turned the water on before I started the ski, and I ran the water for several minutes. I later realized that I should not have turned the water on until the engine was running. So the issue now is, after I pulled the plugs and spun the water out, I can see the fine fuel spray even from each hole. When I put the plugs back in and crank it, it starts for a few seconds then stalls and water come out the exhaust. Upon retry, the engine spins then sounds like its out of time as it barley turns, then will fire again. I know I screwed up, but what do I need to do to correct this? Any help would be greatly appreciated.
Discussion Starter #2
So I messed with is more today and it ran for a little while, now it seems to backfire and spit and occasionally run for a few seconds. Is the a common symptom of the computer going bad, maybe the injectors going bad? Any thoughts?
